It is currently Sat May 02, 2026 2:45 pm
PostPosted: Wed Jan 02, 2013 9:04 am
I'm looking to buy a new set of heads for my 2387 . Just wondering what i should go with ? I'm looking at going with the cb 1409 heads 044 ultra wedge ported 46x37mm what do u think? Will be only riding in the woods.
PostPosted: Wed Jan 02, 2013 7:45 pm
http://www.youtube.com/watch?v=kc5NcPjO ... detailpage
im not sure i did this rite but this buggy also has a 2387 with those same ultrawedge port heads
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Wed Jan 02, 2013 8:05 pm
Any idea what cam and compression your gonna run? What carbs? Also how much rpm do you plan to turn this engine. Personally for a woods motor I would use a set of the CB Super Pro heads. They have alot better port velocity to help with low end torque and are still capable of producing 200HP with the right combo.
PostPosted: Wed Jan 02, 2013 9:47 pm
Southern Buggys / WB Sponsor
Im just throwing this out there....My personal preference is SuperFlow heads with the small valves, VZ25 cam...because out of all the cams available it has a (wider) power range than most cams,44 on the carbs and 1 1/2" for the exhaust,D.U.I. ignition,10.1 on the compression. Building power is one thing, just be sure to spread it out or your not going to have it somewhere along the trail.
PostPosted: Thu Jan 03, 2013 9:02 am
Im running a vz15 cam 10.1 compression and delordo 45 carbs wanting to turn about 6500 max rpm ..
PostPosted: Thu Jan 03, 2013 5:04 pm
the buggy in the video also runs a vz15 cam with dual dellorto 45s... his buggy easily turns 6500 and then some..
PostPosted: Thu Jan 03, 2013 7:43 pm
Ported S/E or 044 super pro Will make more TQ then the wedge ports or S/F . For cam I like the FK 43 with 1.4 rockers or W120 and 1.25 With the 10 to 1 and 45 carbes
PostPosted: Thu Jan 03, 2013 7:57 pm
Speechless...
PostPosted: Fri Jan 04, 2013 12:39 am
im with hyde and aaron on the heads, super pro or street eliminators would be my suggestion with either 42 x 37.5 or 44 x 37.5 valves, also i think you can call and get either one upgraded to the vw650 springs and titanium retainers when ordering them, its cheaper that way than having to upgrade those components a year or so later. the pro gas heads come with these upgrades but the flow rates/port work is a little different than the super pro heads
PostPosted: Fri Jan 04, 2013 3:48 am
Fill us in we are all friends here. 8)
Aaron Creech wrote:
Speechless...
PostPosted: Fri Jan 04, 2013 8:59 pm
Are you running ratio rockers with that cam? If you are,and plan to keep that cam combo,do yourself a favor and get the VW650 spring upgrade.There is no way that a standard dual spring can control the valve at 6500 RPM. My personal opinion is you should scrap that cam and put in something more suitable for a BIG engine with a nice set of heads.
PostPosted: Mon Jan 07, 2013 5:18 pm
Aaron what cam do you perfer ? I bought a set of 1458 Cylinder Heads - 044 Ultra Mag Plus (44 x 37.5mm) 94mm Bore .
PostPosted: Tue Jan 08, 2013 8:27 pm
With those heads I would use an Engle FK-7 or an FK-43. Both with at least 1.4 rockers.The FK-7 will be easier on the valvetrain but may give up a little torque compared to the FK-43.
PostPosted: Wed Jan 09, 2013 9:27 pm
X2 I like the fk 42 or 43 over the fk7 for TQ and HP . I have seen 190 TQ on the dyno with a Fk 43 at 4000 rpm in a 2387
