It is currently Sun May 03, 2026 4:21 am
 Post subject: tire lean
PostPosted: Sat Dec 29, 2012 9:00 pm
im working on getting the angle of the tire right i want a little lean to them look at the right one is it good or to much
 Post subject: Re: tire lean
PostPosted: Sat Dec 29, 2012 9:52 pm
It's leaning the wrong bloody way :lol:
PostPosted: Sat Dec 29, 2012 9:57 pm
say what lol the top should be leaned out slightly
PostPosted: Sat Dec 29, 2012 9:58 pm
no your just looking at it wrong :lol:
PostPosted: Sat Dec 29, 2012 9:59 pm
How was you planing on changing the lean If it's not right?
PostPosted: Sat Dec 29, 2012 10:02 pm
the way the arms are made the bearing housing is welded to a front plate what is not weleded to the arm till you get your tire set how you want then you weld it up solid
PostPosted: Sat Dec 29, 2012 10:07 pm
here is what they are it wil show you what i mean
http://www.woodsbuggy.com/index.php?opt ... f=5&t=3204
PostPosted: Sat Dec 29, 2012 10:45 pm
If you don't like your tyres to work properly, yeah :lol:
PostPosted: Sat Dec 29, 2012 10:48 pm
Am I missing something? I do not see any lean.. If you crank up your torsion you will get a little lean when you are topped out.
PostPosted: Sat Dec 29, 2012 11:01 pm
the right tire tilts out on top is what im talking about a little tilt takes some angle off the cvs i gues most people just have their tires setting cintered
PostPosted: Sat Dec 29, 2012 11:05 pm
Maybe, doesn't take any off the inners though :lol:
PostPosted: Sat Dec 29, 2012 11:34 pm
just drink beer and swear to God you did not know the tires were crooked.
PostPosted: Sun Dec 30, 2012 3:22 am
personaly i like the left side look. but it all depends on your angle, cv degree, and what you decide is end result :wink: listen to the force jesse :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
PostPosted: Sun Dec 30, 2012 4:20 am
haha the angle on the cv is not bad no matter what way i just always thought you wanted a little lean out so when the buggy compresses down when climbing they actually end up more flat to the ground i could be all kinds of wrong would not be the first time :mrgreen: :mrgreen:
PostPosted: Sun Dec 30, 2012 11:30 pm
The lean on the right tire looks good from what as I can tell at least it don't lean like a swing axle lol and yes when your arm travels up your tires will level out that's what u want . If u have stock mouting locations that is looks good to me . Nice buggy. Another way u can adjust lean is to loosen the bolts where trailing arm meets spring plate and take a couple bolts out that will toe the tires in or out then re tighten bolts when satisfied if u can't get what u want weld all the holes shut on trailing arm but one put bolt in and set camber then redrill the rest of the bolt holes . Done this a couple of times . Nick
PostPosted: Mon Dec 31, 2012 8:43 am
don't listen to this guy he cant even spell tire.. :roll: :lol: :lol:
PostPosted: Mon Dec 31, 2012 2:45 pm
Hey, we gave you a complete language and you still managed to fudge it up :lol:
PostPosted: Wed Jan 02, 2013 2:01 am
I didn't spell tire wrong lol
