It is currently Sun May 03, 2026 10:38 am
 Post subject: 1915 cam and valves???
PostPosted: Fri Mar 30, 2012 9:07 am
im saving my pennies to build a 1915.... dont have a hole lot of extra money to put in it... i wonna make it reliable and effective...i know thats kinda to different things... so what is the best combo for the price... i have a holley carb im gonna put on it if dave hix ever gets back with me on a intake... its gonna be infront of a 6 rib... thanks guys
PostPosted: Fri Mar 30, 2012 9:08 am
and what rockers?
PostPosted: Fri Mar 30, 2012 10:04 am
Hard to beat the 110 cam.what are you starting with or are you building from scratch? Chad :mrgreen:
PostPosted: Fri Mar 30, 2012 10:13 am
vz-15 works real good with stock rockers .i used them with 1915 they work. good luck with build.
PostPosted: Fri Mar 30, 2012 10:48 am
stock bottom end and heads... was gonna also run a lightened flywheel...i heard when you up the compression these things really run is that the case...
PostPosted: Fri Mar 30, 2012 12:32 pm
not sure about your carb selection, but ive got a 1915 with dual 44 webers, unported cb o44 heads with 40 x 35.5 valves, lightened flywheel, and a vz 15 cam with stock rockers, my opinion is i really like it other than it lacks a little on the bottem end but i think if i had kept a "stock" flywheel it would have been better but if i ever go back into it i will probably just put a 110 cam in it with either 1.25 or 1.4 rockers and keep the lightened flywheel. my 2 cents
PostPosted: Fri Mar 30, 2012 10:56 pm
Web Cam 218 with 1.25 rockers. 40x35.5 heads with a mild port job and set the compression at 9:1 or so. I also HIGHLY recommend you invest in a counterweighted crank.
PostPosted: Fri Apr 06, 2012 9:12 am
wondering if it was worth getting a lightened flywheel...
PostPosted: Fri Apr 06, 2012 10:05 am
so im thinking w-110 or vz-15 cam.. whats your thoughts...
PostPosted: Fri Apr 06, 2012 5:15 pm
go 110..good all around cam, u cant go wrong with it
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Fri Apr 06, 2012 7:38 pm
My 1915 has c25 scat cam, along with all the other scat internals. 041 heads ( not sure on the valve size or if anything is done) dual weber 40s. Lightened flywheel, pullin the 6rib. the cam definitly lacks on the bottom a bit, but thats nothing a slip of the clutch wont take care of for how it runs all around. I love my setup for what it is. :mrgreen:
"IT IS WHAT IT IS"
PostPosted: Fri Apr 06, 2012 7:42 pm
VZ 15 Stock heads with high rev springs, screamed for 1915. Great performance, reliable also. Sounded awsome, but I'm easily impressed, HAHa
PostPosted: Fri Apr 06, 2012 8:10 pm
I like the W110 or C35 .
