It is currently Sat May 02, 2026 7:09 pm
 Post subject: What size tires?
PostPosted: Sun Mar 11, 2012 12:47 pm
I have a 2 seater buggy with a 1641, single solex carb, bus torsion rear, with a 3 rib trans. I do a lot of trail riding and some hill climbs. What is a god size tire to run? My 1641 pulls good, but I dont want to kill it with to much tire and weight. I think 31 x 15.50 v-treads would be to much so heres the tires I'm looking at right now. All tires will be cut, either TN style cut, or the boggers paddle cut
Super Swamper TSL SX in 30x11.50
Boggers in either 31 x 12.50, 33 x 10.50, or 35 x 10.50 or 14.50
Original TSL in Q78X15C which is a 35" tire
Buckshots in 33 x 12.50
I worry about the bigger sizes being to much for my lil engine. Remember I'll be cutting all the tires because lack of traction bugs the hell out of me. Thanks for your opinions guys, and any suggestions will be listened to as well. Like I said I'm afraid v-treads in 15.50 would be to much for the motor to spin.
Want me hold your purse so you can use the skinny pedal like a man?
 Post subject: Re: What size tires?
PostPosted: Sun Mar 11, 2012 1:25 pm
i ran the 31x15x15 v treads with about the exact same set up and it did great...even with them uncut and on heavy steel rims....ran terras before that....whatever you run will be rougher on cvs so be prepared for that....other than that you should be fine!
PostPosted: Sun Mar 11, 2012 1:41 pm
The width of the tire isn't so much of an issue as the height. A set of 35's will hurt more than the 15.50 width. I would suggest a 31 or 33 bogger. Your not going to be with a 1641 for very long, you will want a bigger hammer, everyone does. Go with a slightly larger tire and build to it, the tire will last longer than the 1641. Also an aluminum wheel helps with rotating mass, helps things live longer.
PostPosted: Sun Mar 11, 2012 1:44 pm
Yeah I knew the taller tire added weight and hurt the gear ratio too. Ill be building a bigger hammer soon enough, but Im on a tight budget so I gotta run what I can for now. I wouldnt mind doing a very wide, cut 31 bogger as long as the motor will pull them good
PostPosted: Sun Mar 11, 2012 2:55 pm
ive always ran 31x15 V treads, had them with my 1641 with no problems. But that little motor was somethin else lol :wink:
"IT IS WHAT IT IS"
PostPosted: Sun Mar 11, 2012 3:46 pm
1641 3 rib will run the v treads just fine.and if you cut them and go to a aluminum bead lock it will even be better.ran this combo for ever with no issues. Chad :mrgreen:
PostPosted: Sun Mar 11, 2012 3:49 pm
Well guess I'm looking for v-treads also now. Mainly I'm looking for cheap lol. Ihate being on such a tight budget.
PostPosted: Sun Mar 11, 2012 5:30 pm
Jesus if only I had a chaindrive
http://lexington.craigslist.org/pts/2829586875.html
34" tall and some big ass bolts.
PostPosted: Sun Mar 11, 2012 6:07 pm
I ran 29 X 12.50 tractor V tread for ten years with a stock motor and 3 rib and was able to do anyting you can expect a stock motor to do. They would be a bit small for a bigger motor though.
PostPosted: Sun Mar 11, 2012 7:26 pm
i like buckshots also they are not a heavy tire way alot less than a bogger and softer
PostPosted: Sun Mar 11, 2012 8:06 pm
V treds for sure! I've got some mcceary v treds that have been cut with 40 tread left on white spoke 15x10 4lug wheels I'll take 200$
Don't let out when in doubt!!
PostPosted: Sun Mar 11, 2012 9:16 pm
31'' tall tire
PostPosted: Sun Mar 11, 2012 9:51 pm
I can't use the rims but if you can email me some pics or text them to me at 850-776-8205 or spots.duncan@gmail.com I'd be interested in just those.
PostPosted: Sun Mar 11, 2012 10:10 pm
Anyone used these? They seem like they would work pretty good, and they are cheap for v-treads
http://www.titantirestore.com/tru-power-tires.html
$273 for a 31 x 15.50 x 15
PostPosted: Mon Mar 12, 2012 9:30 pm
One of my buddys has a set of tru powers, and after he cut them they do pretty good, he is getting ready to cut every other lug out of them because there suppose to do real good like that.
