It is currently Sat May 02, 2026 10:00 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
 Post subject: 4l80e problems!
PostPosted: Sun Feb 26, 2012 3:42 pm
anyone know anything about 4l80e gm overdrive trans.....its in my 91 chevy 1 ton van....takes off in 2nd gear....was throwing code 86-low ratio error solenoid b...changed both solenoids ...now it throws code 81-shift solenoid b circuit error.....still takes off in 2nd...bangs into reverse. have been told it could be in trans or could be in van electrical....?????help i need it to tow buggy to the woods!
 Post subject: Re: 4l80e problems!
PostPosted: Sun Feb 26, 2012 4:18 pm
My truck was doing about the same thing and it was a blown fuse to the ECM.
PostPosted: Sun Feb 26, 2012 6:12 pm
have you changed the trans or ecm lately?
PostPosted: Sun Feb 26, 2012 7:06 pm
changed ecm about 2 years ago....other than that speed input and output sensors on tranny about a year ago
PostPosted: Sun Feb 26, 2012 8:55 pm
ignition switch
PostPosted: Sun Feb 26, 2012 11:31 pm
purplerail wrote:
ignition switch
I agree just cause purp said so
PostPosted: Mon Feb 27, 2012 3:18 pm
all fuses r good...all connections connected....put in new ignition switch this morning and still no luck
PostPosted: Tue Feb 28, 2012 3:32 pm
someone? anyone? 632 views and only 3 or 4 suggestions?
PostPosted: Tue Feb 28, 2012 4:07 pm
try this:
1. First, insert the ignition key and turn the ignition switch to the “On” position (Do not start the engine). Leave the switch on for 11 minutes. The security light may flash or be on steady during this 11 minute period. Make sure the light is no longer on or flashing before proceeding to #2 .
2. Turn the ignition switch off for 30 seconds.
3. Turn the ignition switch to the “On” position (as in step #1) for 11 minutes again.
4. Turn the ignition switch off for another 30 seconds.
5. Turn the ignition switch to the “On” position for 11 minutes a third time.
6. Turn the ignition switch off for 30 seconds one final time.
7. Turn the ignition switch to the “On” position one final time and wait 30 seconds.
8. Attempt to start the engine. If the engine starts and runs normally, the relearn is complete. If the engine does not start, check for trouble codes and address them before attempting the relearn procedure again.
PostPosted: Tue Feb 28, 2012 4:11 pm
I know this is not an answer, but a friend of mine specialize in gm transmissions its all he does.. His name is tony #317-501-1680 give him a call great guy and loves to talk 8)
PostPosted: Tue Feb 28, 2012 5:43 pm
If I could help you I would in a second. I'm as smart as a bag of hammers when it comes to this kind of stuff, sorry.
PostPosted: Tue Feb 28, 2012 6:05 pm
I'm not sure if this will help my truck said the same type of thing yours does and it ended up being the park neutral position sensor. it acted the same way as yours
PostPosted: Tue Feb 28, 2012 6:14 pm
Firebug wrote:
try this:
mine is a 91...will this work on it or is it for obd 2(later model diagnostics)
PostPosted: Tue Feb 28, 2012 6:53 pm
bige70chevy wrote:
Firebug wrote:
try this:
I don't know,,just a shot in the dark,,,probably obd2
PostPosted: Tue Feb 28, 2012 7:43 pm
the early 4L80s had lots of issues with the wiring harness for the trans internal and external if you have a small bolt that goes throught the center of your plug in the harness for your trans then it is early and needs updated :!: I am an ase cert. trans builder at the same shop for 15 years....I can get you the parts if needed or do total rebuild... the wiring kit comes with a new updated internal harness and a new plug and pigtail for the outside that has to be cut and connected
PostPosted: Tue Feb 28, 2012 8:31 pm
ran the trouble codes again after ign switch and now its back to 86 low ratio error (solenoid b closed) have to go to lima tommarow but if i have time i will check plug....its a 91 isnt that 1rst year?
PostPosted: Tue Feb 28, 2012 8:33 pm
i can unplug it and it still starts ? should it?
PostPosted: Wed Feb 29, 2012 8:56 am
yep 91 was the first year,what did you unplug :?: the trans plug or the MLPS( manual lever position sensor)
PostPosted: Wed Feb 29, 2012 10:46 am
nuetral position swich....
PostPosted: Wed Feb 29, 2012 7:56 pm
no the engine should not even crank with the manual lever position sensor (mlps) unplugged, sounds like you got a wiring gremlin
PostPosted: Thu Mar 01, 2012 8:57 am
thats why i was leary of just throwin another trans in...dont want to go through that if its simple as replacing harness or elec prob with van that could be easy fix
PostPosted: Thu Mar 01, 2012 10:37 pm
yes you definately have a wiring problem the van should not start with the switch unpluged. check to make sure you didnt pinch the harness when you installed the tranny. check ecm connecters for corrosion or water intrusion. if you dont find anything I would suspect the ecm? when you clear the codes do they come right back? or do you have to drive it for them to reapear? sounds like the ecm is in "limp in" mode because it dont know what gear you have selected?
PostPosted: Fri Mar 02, 2012 12:32 pm
it is the original trans...just started trippin last week....if i clear codes it takes a while to come back...ecm new a couple years ago
PostPosted: Fri Mar 02, 2012 10:33 pm
Oh sorry I thought you said you changed the in an earlier post but I see I read it wrong. Does it start in second after you clear the codes or only after the code sets? Does third and overdrive work? Torque converter clutch work?
PostPosted: Sat Mar 03, 2012 11:16 am
yes it always starts in second...if you manually put it in L1 it feels like the brake is on and trans struggles to move truck...shift it into any other gear and it will go but it takes off in second....will down shift from od to D and torque conv seems to be doin its thing okay....also when you put it in reverse it engages very hard
