It is currently Sat May 02, 2026 7:06 pm
 Post subject: axle help
PostPosted: Tue Jan 24, 2012 4:51 pm
my axle is popping, where can i purchase some axles and how do i knoe what size to order thanks again guys
 Post subject: Re: axle help
PostPosted: Tue Jan 24, 2012 5:16 pm
Popping sounds are usually a cv or maybe tranny. The length of the axle depends on what rear trailing arms you have.
PostPosted: Tue Jan 24, 2012 9:57 pm
well what do you measure to get the correct axle for your arms, i have no clue what arms i have
PostPosted: Tue Jan 24, 2012 10:03 pm
Does the axle float smooth in the joints. Grab the axle a wiggle it in and out from the wheel towards the transaxle. If the axle has good movement then just pull the axle out and measure the length. Its not gunna be the axle itself, its gunna be a cv joint. You can also set an angle finder on the top of the axle with it bolted in and check the angle. Depending what cvs you have determines the max angle you can have.
PostPosted: Tue Jan 24, 2012 10:07 pm
also the splines on the axle could be messed up if so just that a file in between them all the way around till your cv sides on the axle easy
PostPosted: Wed Jan 25, 2012 1:11 pm
The best way to measure for an axle is to remove your axle and cv's, compress your suspension so that the stub axle and drive flange are level with each other, then measure from the inside (deepest point) of the stub axle cup to the inside (deepest point) of your drive flange. Get the axle that is as close to this measurment without equaling it. example= if you measure 18-7/8" get a 18-3/4" axle.
PostPosted: Wed Jan 25, 2012 6:16 pm
Exactly :wink:
