It is currently Sun May 03, 2026 9:13 pm
 Post subject: Clutch setup
PostPosted: Mon Dec 10, 2007 10:54 pm
What type of clutch with what torque / horspower is everybody running?
I just ordered a Stage 3 pressure plate with a standard clutch disk to go with the dodge turbo engine Im installing. 174hp 200ft lbs of torque.
PostPosted: Mon Dec 10, 2007 11:10 pm
I have the Kennedy Stage 2 2100lb. With your HP I think the 2600lb would be better in the long run.
The Wild Kids
PostPosted: Mon Dec 10, 2007 11:38 pm
I run a Subaru 2.2 at about 140 hp. I started with stock pressure plate and clutch disc. Kept burning disc. Went to Kennedy stage 2 pp and stock disc.. burnt disc. Went to Stage 2 pp and kushlok and am happy as can be. :)
and stock pedal set,,,,,what's up with hydraulic,,,,,,hyrdraulic is for cooling
PostPosted: Mon Dec 10, 2007 11:54 pm
yup, same here kennedy stage 2 pp and cushlock clutch, 200+ hp, 200 lbs. torque
Mike
Got Honda?
PostPosted: Tue Dec 11, 2007 12:27 am
The guy at kennedy suggested I go with the stage 3 is this to much? Will I still be able to push the clutch in with one leg? The cush lock disk is coming with it. :?
PostPosted: Tue Dec 11, 2007 12:45 am
I ran a stage 3 with a 3 puck hyd clutch with a 5/8 bore on m/c
PostPosted: Tue Dec 11, 2007 2:07 am
I am running a Kennedy 4-puck clutch, a Kennedy stage 1 pressure plate, and a CNC hydraulic slave cylinder ran by a 3/4" bore CNC series 254C. Never slipped or burnt one up yet.
PostPosted: Tue Dec 11, 2007 9:09 am
I have a Kennedy Stage 2 228mm PP with a stock bus 228mm disc on a 2666 type IV. Never slipped when I didn't want it to. I even slipped the clutch climbing rocks so bad one time that it discintegrated the disc but still wouldn't slip (although it would not disengage). I use a stock Vanagon hydraulic slave cylinder and the pedal is easier to push than any car or truck clutch pedal.
PostPosted: Tue Dec 11, 2007 9:52 am
[quote='Firebug']
and stock pedal set,,,,,what's up with hydraulic,,,,,,hyrdraulic is for cooling[/quote]
Firebuggy you run a stock set up? :?: Well on day we will get you converted to a A/C.
I run a stage 4 clutch , with a 1641 with the valves drilled, with a stock cable pedal set up. (the only way to go)
PostPosted: Tue Dec 11, 2007 11:46 am
Like I said, hydraulics are made for cooling. Air is good too,,,to run through radiators. 8)
PostPosted: Tue Dec 11, 2007 11:53 am
badvw if you switch to a 5/8 your clutch will be easer to press
PostPosted: Tue Dec 11, 2007 12:38 pm
Be sure to upgrade the throw out arm Huey.
Some of the stock ones are pretty pathetic.
I assume you are using a VW tranny.......... :wink:
PostPosted: Tue Dec 11, 2007 12:43 pm
[quote='rockrockets1']badvw if you switch to a 5/8 your clutch will be easer to press[/quote] It may be easier, but it will have to travel more because of the surface area of the piston (more=less travel) and it also depends on your brake line too (smaller, but not too small=less travel), I think I used to have a 5/8" bore on my old buggy, but don't remember. Once you get it adjusted right, you can just barely push it in and it will disengage, to help allow you to power shift q
 Post subject: stage 1
PostPosted: Tue Dec 11, 2007 7:44 pm
I run a stage 1 kennedy with a cushlock, 36 inch buckshots with a stock 091 tranny. Same clutch for past four years. To me its worked out well.
PostPosted: Tue Dec 11, 2007 7:52 pm
So, I still don't see anyone running a stage 3 pp. I am running a 3-rib trans with the top mounting ears on the bellhousing. It has the collar for the throw out bearing to ride on. Do I still need to upgrade the arm (turboblue)? bruce 1 did you upgrade your arm with the stage 4? Do I need to send the stage 3pp back and get the stage 2pp? I know the 3-rib is a little weak but its what I have.
Thanks guys for all the input...
 Post subject: Yes
PostPosted: Tue Dec 11, 2007 8:17 pm
Yes any time you run a pressure plate any larger than stock you should upgrade your throw out bearing arm. What size tires are you planning on running. That is where you really have to have the clutch strength. The bigger the tire the more rotating weight you have to turn.
PostPosted: Tue Dec 11, 2007 8:45 pm
Ok, where and what part number do I need for the throw out bearing arm.? What about moore parts? My tires are just 28 X 12.50 X 15 tractor lug tires. Smaller tires are easier on the trans.
 Post subject: dans
PostPosted: Tue Dec 11, 2007 9:22 pm
Go to Dans performance parts.com goto on line shopping. Scroll down to clutches. Scroll down and you will see the HD arms. You will need to replace the bushings and all.
PostPosted: Tue Dec 11, 2007 10:09 pm
Ok, I think my transmission is the type 2 (3-rib with upper mounting holes). Which part number 01-98-1412-0 or 01-98-1410-0? I don't see the bushing kit for either one of these.
PostPosted: Tue Dec 11, 2007 11:36 pm
Why not just call Tim at the bug shop in london ky that would only be about a 1 hour drive south for you. 606-864-2217. He is a great guy, and would have anything you need.
PostPosted: Wed Dec 12, 2007 1:12 am
[quote='Huey']So, I still don't see anyone running a stage 3 pp. I am running a 3-rib trans with the top mounting ears on the bellhousing. It has the collar for the throw out bearing to ride on. Do I still need to upgrade the arm (turboblue)? bruce 1 did you upgrade your arm with the stage 4? Do I need to send the stage 3pp back and get the stage 2pp? I know the 3-rib is a little weak but its what I have.
Thanks guys for all the input...[/quote]
I know that some people likes to
PostPosted: Wed Dec 12, 2007 8:17 am
I run a stage 4 clutch and presu
PostPosted: Wed Dec 12, 2007 9:16 am
lots of different clutch set ups will work, It has a lot to do with how you ride.
PostPosted: Wed Dec 12, 2007 9:31 am
I run a Stage 1 pressure plate with a cushlock disc. No problems in 4 years.
PostPosted: Wed Dec 12, 2007 1:42 pm
[quote='Roy']I run a Stage 1 pressure plate with a cushlock disc. No problems in 4 years.[/quote] I used to have this setup, it works really good too! I guess I kinda got spoiled with the 4-puck idea, I love it! :D
