It is currently Sun May 03, 2026 3:24 am
PostPosted: Tue Sep 20, 2011 10:59 pm
Lookn for a power steering pump and mount for a VW motor. Gettn tired of fighting the wheel.
PostPosted: Thu Sep 22, 2011 5:57 am
DVS1:
I have a pump mounting bracket that I will take $50 for, plus shipping. This bracket uses a '93 Mitsubishi Eclipse pump that you can order from any Autozone or Advance Auto Parts or usually find at any U-Pullit (I don't have an extra pump right now).
I have this bracket/pump combo on my own buggy as well as my wife's autostick buggy. I cut these out on my CNC plasma cutter and weld them up.
Let me know if you are interested and I will send pictures.
Dale
Lets RIDE!
PostPosted: Thu Sep 22, 2011 9:23 am
do u have any pics of this bracket ???? i would like to see it thanks
PostPosted: Thu Sep 22, 2011 8:37 pm
The unmounted bracket is the solid-mount version ($50). With this one the belt tension adjustment is the same as always, using the shims in the alternator pulley. The mounted bracket is the adjustable version ($75). The belt tension can still be adjusted with the shims, but it is way easier to loosen the slide bolts and use the allen head bolt.
If anyone needs one of these PM me and I will get one ready. Obviously, the unmounted bracket can ship immediately.
Thanks,
Dale
Lets RIDE!
PostPosted: Thu Sep 22, 2011 8:41 pm
is that a eclipse pulley also ???
PostPosted: Fri Sep 23, 2011 3:58 am
I like the adjustable one. But my problem is that I run a serpintine belt and would need a pump with a serpintine pulley.
PostPosted: Fri Sep 23, 2011 5:11 am
The single V-belt pulley is what comes with that model pump from the Eclipse. This is a fairly common item in the salvage yards and I have seen it on other cars such as Chrysler Laser and a few others. I have also seen the serpentine pulley on that pump but I am not sure what cars you might find it on.
I would be concerned about alignment with the wider belt. I have always used the single V-belt model and the pattern I have worked out on the plasma cutter aligns perfectly. I could cut the pieces and you could weld them yourself to get the alignment right or send me a template of what you need and I can scan and cut.
Lets RIDE!
PostPosted: Fri Sep 23, 2011 7:38 am
I use a dubble crank pully setup. look at dave hix set up its nice. :mrgreen: When i ran a single belt every time i got water on it will squeel.
PostPosted: Fri Sep 23, 2011 10:06 am
You gotta be tough, work on some forearm exercises with a dumbell :twisted: :twisted:
PostPosted: Fri Sep 23, 2011 10:12 am
I hear them sqeal all the time. That is why i did away with the belt.
PostPosted: Fri Sep 23, 2011 11:43 am
Theres a smartass in every crowd! :lol:
PostPosted: Fri Sep 23, 2011 11:47 am
Dave there are more enjoyable ways that don't even feel like work :roll:
Trust me Dave, you will love power steering. Great going downhill :mrgreen:
