It is currently Mon May 04, 2026 10:46 pm
 Post subject: Pressure plate
PostPosted: Sun Sep 18, 2011 8:54 pm
Let me just say i really like this site.I have been building a buggy for some time now and its most done :D Chuck Jones built my frame and Dave Marks is building my motor and Tim from Southern Buggys is putting it all together. But i have a question going to use a kennedy pressure plate but what pressure I have a 2387 and a stock 6 rib. thanks Phillip
 Post subject: Re: Pressure plate
PostPosted: Sun Sep 18, 2011 9:03 pm
Phillip! I love ya but I am sitting here trying to catch a buzz. Just ASK TIM!ahhhhhhhhhh!Or just get on a floatation device and come here and ride with us!
PostPosted: Sun Sep 18, 2011 9:09 pm
I have asked just curious on what others would say :D
PostPosted: Sun Sep 18, 2011 10:37 pm
I like a Kennedy stage 4 but 2 or 3 is fine too,,,with a 6 puck,,,others will beg to differ
edit: 2000 pound car with 230 hp
PostPosted: Sun Sep 18, 2011 11:06 pm
stage 2 with cush lock disc
PostPosted: Sun Sep 18, 2011 11:40 pm
x2
PostPosted: Mon Sep 19, 2011 10:38 am
I have good luck with stage 3 on my 2387
PostPosted: Mon Sep 19, 2011 12:20 pm
I always ran a stage one with a 4-puck in my race buggy with a 170+ hp 2332, and it never slipped. Running a heavier than needed pressure plate is a BAD thing for your motor, trans, and foot! Ok, now everyone tell me i'm crazy! :roll:
PostPosted: Mon Sep 19, 2011 12:52 pm
I run a stage 3 with a 4-puck, that's for a heavy car with ~170lbft and full race launches off the line, never had any trouble with clutch slip.
Have more than enough power and rpms available in first gear to never need to feather the clutch though, that may be an issue for you
PostPosted: Mon Sep 19, 2011 7:30 pm
A 2387 puts out a lot of torque so if the car weighs less than 1600#s then a stage 2 Kennedy with a Cushlock (not the EMPI copy). If it weighs more than 1600#s then I would consider a stage 3 with a 6 puck Kennedy plate. Note: The 6 puck is a little grabby. Personally I do not recommend a 4 puck on a Woodsbuggy. Ok for racing however way to grabby for the slow technical trail riding IMHO.
PostPosted: Mon Sep 19, 2011 7:46 pm
The heavier the pressure plate, the more the thrust cut on the block wears.After long neglect all that slamming will wear out your flywheel main bearing and it will not fit tite in the saddle.Then your end play will be loose and it will then play games with your brass timing gear.
PostPosted: Tue Sep 20, 2011 2:24 am
hey ody who makes the kush-loc if the ones empi has are not the real deal?????
the last stage 2 p. p. i bought was in a empi box but it had kennedy stamped in it and i just assumed the kush-loc disk were the same way :oops: :?
PostPosted: Tue Sep 20, 2011 11:38 am
my first season racing I would beat the thrust out in about 2 races! I have always ran a 4 puck in all my buggies, race or woods, and personally I love it! You can get away with a lighter pressure plate! I switched to a stage 2 aluminum kennedy pressure plate when I put the suby in the race buggy and it didnt last 10 minutes and kennedy didnt have any good words for me after that. I'm considering a different brand now.
PostPosted: Tue Sep 20, 2011 1:13 pm
Daikin Super disk is the original Cush loc clutch. China makes a similar product branded Kush-loc however not the Daikin quality. The Super disk can be bought at a lot of places.
Heres one link:
http://www.vwparts.net/AC141150.html
PostPosted: Tue Sep 20, 2011 5:02 pm
Heres one link:
thanks for the info ody :D
