It is currently Sat May 02, 2026 8:38 pm
 Post subject: Mounts breaking
PostPosted: Mon Sep 05, 2011 11:28 pm
Ripped both tranny mounts on my nose cone out. Don't know if this is something that happens a lot but whats a good way to help prevent it from happening again??
 Post subject: Re: Mounts breaking
PostPosted: Tue Sep 06, 2011 1:22 am
Use the bus adapter kit with the center and bell housing straps. There is also mounts that bolt to the tranny where the nose cone and the body mounts together. And dont forget to make a mount to the top mounting holes on top of the bell housing.
PostPosted: Tue Sep 06, 2011 8:49 am
I didn't think of putting some for the top of the bell housing, that makes a lot of sense. I don't see any other mounts though for where the nose cone and body mounts together... it is a 3 rib
PostPosted: Tue Sep 06, 2011 12:21 pm
If your bell housing has the two top mounting holes you could take advantage of them and run some bracing upwards and outwards,,,or some sort of ridged and solid hanging system braced off the frame. Stiffen it up at all mounting locations for best support.
PostPosted: Wed Sep 07, 2011 1:10 am
firebug you sold me the bell housing it doesn't have the ears. i thought about what you said more
wouldn't that not work because the starter?
PostPosted: Wed Sep 07, 2011 12:35 pm
http://kartek.com/Media/Catalogs/Kartek ... _small.pdf
look on page 46 for the trans mounts. they have the common ridgid mounts and the flex mounts.
PostPosted: Wed Sep 07, 2011 1:14 pm
those flex mounts are sweet
PostPosted: Wed Sep 07, 2011 3:34 pm
yeah, but just a little pricey! :shock:
