It is currently Sat May 02, 2026 8:22 pm
 Post subject: Spilled oil on my brakes
PostPosted: Tue May 17, 2011 1:14 pm
Alright, bout 2months ago I spilled motor oil on my driver side rear caliper, pads etc...after i bleed the brakes from replacing a line, that side just will not work right. Went riding for a weekend thinking it would maybe get better, stilll not right. Think the oil ruined the pads?
"IT IS WHAT IT IS"
PostPosted: Tue May 17, 2011 1:31 pm
yup...had same problem on my powerstroke...got tranny fluid on passenger side when cooler line broke....new pads and rotor turned did the trick
PostPosted: Tue May 17, 2011 2:57 pm
You can try boiling the oil out of the pads with some heat however no guarrantee. Do not get them too hot as it will make them crumble. BTW do not breath the fumes.
PostPosted: Thu May 19, 2011 12:52 am
alright ill just get some new pads. havent changed them in 4yrs anyways lol
"IT IS WHAT IT IS"
PostPosted: Thu May 19, 2011 12:51 pm
" 4 Years" I get 4 rides out of a set if I'm lucky. :roll: Here I am thinking you just Installed new pads DUH!
PostPosted: Thu May 19, 2011 4:21 pm
Stick some Carbotechs in.
We used to munch a set per meeting or two, no matter what we used, switched to XP8's and the same set are still in the front 18 months later...
PostPosted: Thu May 19, 2011 6:34 pm
soak em in gas for a few hours then let them dry in the sun. Or just spray em good with brake parts cleaner and ley it go. They'll shape up.
PostPosted: Thu May 19, 2011 6:39 pm
ill try that before i get new ones. Ody, when ya dont drive a tank the brakes last a lil longer!!! PLus i dont do 90mph down the trails so brakes get little abuse haha :mrgreen: :mrgreen:
"IT IS WHAT IT IS"
PostPosted: Fri May 20, 2011 9:28 am
And your Point Is! :roll: :wink:
PostPosted: Fri May 20, 2011 3:21 pm
I suppose there could be a few points, I drive slow. and I need turbo'd suby tank with boggers?? lol
"IT IS WHAT IT IS"
