It is currently Sat May 02, 2026 11:04 pm
 Post subject: Battery, Crank sensor
PostPosted: Fri Nov 30, 2007 9:46 pm
Hi guys, I am new to buggys. I have read every post on this forum at least twice. This is my first post and my first buggy build. I have a couple of questions........Where we ride at there are a couple of river crossings. 1.Should I mount the battery higher on the frame? What if the battery becomes submerged for a short period of time? I will be running a GM 3800 V-6 with the computer and all the sensors ( the computer will be mounted in the roof of the driver compartment). This question is for the W/C (Subie) guys......2.Will submersion/ Mud hurt the crank/ cam sensor. If so how do you water proof it? Now you A/C guys be nice. I love your buggys and know that I will never climb like you. I have seen some really awesome videos. Nearly unbelievable. Thanks for any help, Tom :D
PostPosted: Fri Nov 30, 2007 10:09 pm
HI,,, welcome to the Woodsbuggy community. I run a Subaru ej22. I put all my relays, computer, and any loose components in an ammo box and sealed the harness entry point. The sensors are pretty much sealed from the factory. I have not submerged this engine but have rode in hard rain several times with no problems. After each ride, I usually stop at the carwash and give it a good going over. I have my battery mounted on floor level as do most others. My buggy is water friendly. :P
PostPosted: Fri Nov 30, 2007 10:47 pm
Thanks a whole heap. Ammo Box HMMMM.......I have a couple of those laying around. That is exactly what I wanted to know. I really enjoy watching everybody's videos.I am amazed at some of the stuff you guys do. I hope my buggy turns out to be half the buggy as some of your alls. Thanks again Tom
PostPosted: Sat Dec 01, 2007 12:33 am
Crank sensors are usually magnetic pickup style, so there should not be a problem with that. But totaly submersing the battery is another story that I can't answer.
PostPosted: Sat Dec 01, 2007 1:52 am
ammo boxes for sure!!.... i use 2....1 for cpu and 1 for relays/fuses :)
Mike
Got Honda?
PostPosted: Sat Dec 01, 2007 5:16 am
Submerging the battery for short periods of time will not hurt a thing.
Roy
PostPosted: Sat Dec 01, 2007 9:43 am
Seal all connections with di- electric grease and they will be fine
PostPosted: Sat Dec 01, 2007 12:43 pm
Thanks for the help guys.......that eases my mind about the electronics. Tom
PostPosted: Sun Dec 02, 2007 9:22 am
Since your only about 1 hour from D&K you need to come ride with us. It will be some of the best fun you will ever have!
Welcom to the site and Keep on posting.
 Post subject: batteries
PostPosted: Sun Dec 02, 2007 10:34 am
the thing to remember about a batt is that the top of it needs to stay clean . If dirt accumulates on top of a batt along with water ---- will cause a draw across the posts ---water that is clean will not cause this to happen.So clean post area after riding.
PostPosted: Sun Dec 02, 2007 1:34 pm
Bruce, Since this is my first buggy and my first attempt at building one I'll have to pass right now. Maybe after I get a little seat time, and if the buggy performs like I want it to, then yes I would love to. We will just have to see.There are several buggy's around these parts but they never get together and ride. I hope to change all of that. There is alot of good riding around here. I will probably have some sort of cover for the top of the battery, it just won't be water proof. Tom :D
