It is currently Sun May 03, 2026 9:02 am
PostPosted: Sat Feb 05, 2011 5:32 pm
ID LIKE TO SEE WHAT YOU GUYS ARE RUNNING...
Don't let out when in doubt!!
PostPosted: Sat Feb 05, 2011 5:48 pm
Get you a set of 3 rib tractors and cut slots into them so you can get more traction.I found this to be the cheapest route versus buying a set of the hay rake tires for $200.
PostPosted: Sat Feb 05, 2011 6:05 pm
the 3 rib tractors are only like 25 in tall and only 5 inches wide wanting a lil taller and wider???
PostPosted: Tue Feb 15, 2011 9:37 pm
7.00x15 bias snow tire. they are about 30 inches tall
PostPosted: Tue Feb 15, 2011 10:03 pm
Go to the junk yard and get 2 16"donuts out of a Jeep or something and cut the welds out andknock out the center.Then mount some 750x16's and you will have 32.5". Look at my post under buggy builds and scroll down to the wheel.Tires (3 ribs) tacks n tubes are $250.A little tougher to steer but will roll over anything and a soft ride.
PostPosted: Sat Jul 02, 2011 2:05 am
Tires pictured look like my Dunlop snow crushers. They're almost 29" tall and bite the muck pretty good.
PostPosted: Sat Jul 02, 2011 1:05 pm
Most people call these "Home Plate" Tires.. Probably one of the most popular tires used.
PostPosted: Sat Jul 02, 2011 4:45 pm
these are my favorite
PostPosted: Sat Jul 02, 2011 6:51 pm
they work well some guys say turning them around backwards makes them steer better
PostPosted: Sun Jul 03, 2011 12:28 pm
Backwards whould make them brake better, the force is the opposite of what a drive tire is. backwards would clean the tread instead of clogging and sliding.
PostPosted: Sun Jul 03, 2011 2:50 pm
i dont think what tire you got in the font even matters unless you drive the road cause their not even enough weight to matter so go with what you think looks best to you
PostPosted: Fri Jul 08, 2011 9:36 am
I like my bald 7.5 x 15 ribbed implement tires. They don't throw mud at you all day long in the trails (and with about 6 oz. of airsoft beads in them they balance real nice at 70 MPH too). If it is that muddy where you are playing you will be steering with the cutters and not the front tires anyway. A bunch of the guys I talked to at DIRT DAYS that had luggy front tires said they look cool and thats about it.
PostPosted: Mon Aug 22, 2011 10:08 pm
A tall street tire or tall 3 rib tires. All the others just look cool and fling so much crap at the driver. I know I have 7.00-15 power kings. I'm just keeping them for the height they give me and the coolness factor 8) . In reality when you are in the woods must of my steering is with the steering brakes. I use the steering wheel very little.lol Yes, my tree bars are straight still too. :D
