Hayshaker
Many head porters like the 043 casting. For others it does not matter. A stock VW dual port head with 35.5mm intake and 32mm exhaust valves breathing throuigh 44 IDFs will flow 126 cfm at .450 lift and at .600-in lift the flow is 139cfm.
A how to link with pictures.
http://knol.google.com/k/modifying-vw-t ... rformance#The trick is going to be making all four flow the same with out a way to measure air speed and cfm. Very fast air speed from small volume ports is what gives great throttle response. The Bergs and Steve Tims are two of the best porters when it comes to air speed. If you don't like how yours turn out Steve Tims Stage One heads should work great with a VZ 14 cam for the 1915 or VZ 15 for the stroker. Setting up your springs and match porting your intakes is included in the price. For a little more he can adjust the combustion chamber volume to get better deck height. Call and talk to Steve (
http://performance-workshop.com) as he will want to know how your going to drtive it low speed twisty trail with short 200 foot straight aways or half to full throttle open trails, engine size, cam, carbs vehicle weight and gearing. Note how the port volume between the different heads does not change much, that will be you challenge if you port your own heads.
Going big won't hurt either.
When using a pre race prepped aluminum case and all new parts a 90x94 is not much more than a 69x94 or 78.8x94.
DPRs standard 90 mm stroker crank is $440.00 his 78.8 mm stroke crank is $300. CB H beam rods are about $100 more than CB or Scat Unitech rods. I like the heavier crank but that is $200 more. For the 90x94 size engine with the VZ 15 cam you will need Stage Two heads with Stage One port volumes. Stage twos are $200 more than Stage ones.
Unless your a hardcore driver the 1915 should be plenty.
