It is currently Sat Apr 27, 2024 8:56 pm
Board index » Blogs » The Thoughts of Odyknuck
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
 Post subject: Ultra Beadlocks
PostPosted: Thu Sep 18, 2008 4:11 pm
As some of you know I have had major Issues with flats on my new Buggy. After doing a lot of research on Beadlocks I decided that what was commercially avalable was not to my liking so I decided to make them instead. So off I go to my Buddies CNC shop and explain my situation. Of cource he was in total agreement and we set out to design and build our own. Due to the nature of Woods abuse on wheels the material selected was 1/2" thick Billet Aluminum. The outer ring is 3" wide and the Inner ring is 2" wide. The design criteria was based on the following thoughts: Major heavy duty, draining water out of rim, self centering tire, anti coning, strength and of cource they had to look good. First a rough sketch was made and modified several times to suit me. Then an ACAD drawing was produced of the design. The drawing was then downloaded into a CNC for preliminary test run purposes. A few minor adjustments in the run stage and off we went. Note to self, the next ones we do we have an anti coning step on the inner ring. It will need to be made with 3/4" material to accomplish this. For the protype I used .100" thick flat washers on the bolts between the rings to help with the coning. Shown below are the various stages of the prototype starting with cutting off the OEM outer bead thru various machining process's to welding the new inner ring on and then the final result of the mounted and polished beadlock on my Buggy . BTW The CNC program is written for these so if any one is interested in a set let me know and for a nominal fee I will hook you up. Special thanks to my Buddy Dave the owner of Precision Machining and Surfacing for taking the time to do this for me. Its really nice to have good friends.
Rim with Bead cut off
Close up of bead cut off
Beginning of Machining process
Cutting of the 36 3/8" bolt holes and drains. Stage one complete
Cutting of Kidney drain slots and inner scallops comple. Now the Tire bead step is machined in the outer ring. A 1/4" radius is also machined on the outer edge of the ring so it will not cut into the tire when using low air pressure.
One of the CNC machines used in the process. We used two machines to keep the process moving.
A completed inner ring welded on to rim . I was not there to take pics of the inner ring process.
Hex's machined in to the inner ring for the nylock nuts.
Installing the nylocks in the inner ring. They are a press fit so they stay in place and can be easyly replaced.
Inner and outer ring showing the the steps for self centering and support of the tire bead.
A completed Beadlock installed with tire in place.
Close up
 Post subject: Re: Ultra Beadlocks
PostPosted: Thu Sep 18, 2008 4:27 pm
BLING BLING!!
PostPosted: Thu Sep 18, 2008 5:45 pm
Steve wrote:
BLING BLING!!
Don't ya mean CHA CHING.
Aint numerical control machines neat.
Looks real nice, should do the job for ya. Can't wait to see to see them on Saturday.
PostPosted: Thu Sep 18, 2008 8:16 pm
And I thought I was Captain Overkill
PostPosted: Thu Sep 18, 2008 8:40 pm
You are Captain Overkill
Odieknuck is Mr. Captain Overkill, Sir.
PostPosted: Thu Sep 18, 2008 8:47 pm
Close up[/quote]
tweek the program a little bit and make the drain holes into little hearts, you'll make a killing on valentines day :lol:
- Sigmund Freud
- Antonio Meloni
PostPosted: Fri Sep 19, 2008 1:43 pm
Ah! come on guys it's not that overkill. Besides with CNC flexibility why not! Remember we are talking Wellsville terrain here. :roll:
PostPosted: Fri Sep 19, 2008 1:44 pm
plumberbill wrote:
Close up
tweek the program a little bit and make the drain holes into little hearts, you'll make a killing on valentines day :lol:[/quote]
I guess we will have to make that set for you Bill. :lol:
PostPosted: Fri Sep 19, 2008 1:49 pm
MadMike wrote:
Steve wrote:
BLING BLING!!
Yea "Cha Ching" is right and so is Bling Bling. :lol: After looking at whats on the market these will be resonablly priced . You know the drill "You get what you pay for". As Roy allways says "Buy the best and Cry Once".
PostPosted: Fri Sep 19, 2008 1:51 pm
Chaindrive Rail wrote:
My highest response: Damnit man!!!
LOL
Curt
Curt I will assume that was a complement and Thank You 8)
PostPosted: Fri Sep 19, 2008 4:09 pm
very nice!
Mike
Got Honda?
PostPosted: Fri Sep 19, 2008 6:20 pm
Reasonably priced is a loose term :lol:
PostPosted: Sun Sep 21, 2008 6:51 pm
Hill Climber
I got to see them yesterday. They are killer.
Harry S. Truman
PostPosted: Sun Sep 21, 2008 7:04 pm
WOW. :!:
PostPosted: Sun Sep 21, 2008 9:43 pm
very nice ODY fit and finish are awsome
PostPosted: Mon Sep 22, 2008 8:32 pm
615 Hubbard rd manchester KY Send me a set I send the green I love seeing people make thing happen.Only thing tthat would be any COOLER is them on my buggy I LIKE IT.
If it feels good, hold it to the floor and pour it to it!
http://www.dandkoff-roadpark.com/FORSALE.html
PostPosted: Tue Sep 23, 2008 12:06 am
Are they for sale? Well not these but others
PostPosted: Tue Sep 23, 2008 1:58 pm
Yes they are avalable to the public. I spoke with Precision Machine today and he is looking into material costs etc. to come up with a price. I will let you know ASAP. They will be offered two ways, one as a complete kit that you would weld on or he can weld them on to your rims. Either way the existing bead needs cut off for best results.
PostPosted: Tue Sep 23, 2008 4:27 pm
I don't know, he's going to need to fancy them up some :mrgreen:
PostPosted: Tue Sep 23, 2008 5:55 pm
I want a set with SUBARU emblems in them!!! :D
PostPosted: Wed Sep 24, 2008 8:53 am
now that would be cool 8)
- Sigmund Freud
- Antonio Meloni
PostPosted: Wed Sep 24, 2008 9:23 am
Figure me in too... :wink:
PostPosted: Wed Sep 24, 2008 9:48 am
Thats what I like about you Mike allways the Funny guy! :lol:
PostPosted: Wed Sep 24, 2008 9:49 am
I am sure it can be donne. All it takes is money. :wink:
PostPosted: Wed Sep 24, 2008 12:53 pm
can he make a set of beadlock "spinners"? :mrgreen: j\k Those are nice!
Users browsing this forum: No registered users and 8 guests
