It is currently Sat May 02, 2026 5:14 pm
 Post subject: tranny manual
PostPosted: Tue Jul 08, 2014 8:51 pm
Does any buddy know were I can buy a manual on how to rebuild bug and bus trannies?
 Post subject: Re: tranny manual
PostPosted: Wed Jul 09, 2014 8:39 am
not sure on manual but there is a video for sale out there. there isn't a ton to know about rebuilding them. if you can rebuild a motor, you can rebuild a trans. You just need to spend a few hundred bucks on tools and a jig.
PostPosted: Wed Jul 09, 2014 9:42 am
Thanks, I did find the vids, and the same place sells a really nice jig for setting up the shifts forks, Looks like I will be spending some bucks to get all the right tools
PostPosted: Wed Jul 09, 2014 10:00 am
Do you have a link to that?
PostPosted: Wed Jul 09, 2014 10:34 am
http://www.longenterprises.com/vw_transaxle_tools.htm
PostPosted: Wed Jul 09, 2014 10:41 am
PostPosted: Wed Jul 09, 2014 10:49 am
Thanks rick!!
PostPosted: Wed Jul 09, 2014 10:58 am
Yep that's the place I found last night, Putting in a order hopefully this week
PostPosted: Wed Jul 09, 2014 7:37 pm
If you don't want to spend the money on a jig I made one out of a old 3 rib case and its just setting here if you would want to borrow it and promise to give it back but only if you promise
PostPosted: Wed Jul 09, 2014 10:04 pm
Truthfully the only special tools you need is a pinion nut socket, an old tranny case cut out, and some skills.
PostPosted: Thu Jul 10, 2014 12:15 pm
be careful if you do the homemade jig!!! I made one for 3 ribs, rebuilt about a dozen trannys and then found out every one of them was off just a little on the 3rd/4th fork. It was a BLAST re-rebuilding them after that. My 6-rib jig always worked out good for me. it is well worth the money for the jig I ended up buying.
PostPosted: Thu Jul 10, 2014 10:05 pm
I have to agree. Really don't need much to do these things. Pinion nut socket, socket for the screw in side pieces for the diff bearings, a good shop press and a good bearing separator (clam shell) and your in business. Good common sense and some experience and you are set. They are really simple once you do a couple you will see.
