It is currently Sun May 03, 2026 2:19 am
 Post subject: smoke
PostPosted: Sun Oct 30, 2011 10:08 pm
what would make a motor blow oil smoke out of the blow by next to the oil filler cap ? the motor runs the same and has the same power
 Post subject: Re: smoke
PostPosted: Sun Oct 30, 2011 10:43 pm
WB Competitor
im still learning about vw engines so this may be a stupid question but do you have a crankcase breather? internal pressure has got to go somewhere.
PostPosted: Mon Oct 31, 2011 7:28 am
Ck compression it probably has a low cylinder or oil ring bad , also common thing if it has c clips on your wrist pins one may have popped and scored your cylinder .
Just a couple of suggestions , good luck
Jason
PostPosted: Mon Oct 31, 2011 12:10 pm
just a little smoke, or a bunch?
PostPosted: Mon Oct 31, 2011 9:02 pm
it smokes when im getting on it alot
PostPosted: Mon Oct 31, 2011 9:24 pm
WB Competitor
rings maybe. thats what was wrong with mine.
PostPosted: Tue Nov 01, 2011 12:02 pm
rings would be my first guess too!
PostPosted: Tue Nov 01, 2011 12:31 pm
WB Competitor
do you have a crank case breather? if so is it getting a lot of oil in it? mine did and it was the rings. i did not notice alot of power loss at first but did over time. ended up replacing the jugs, pistons, rings and bearings and now its good to go. dont wait as long as i did because i ended up with a quarter inch ring gap. not good.
PostPosted: Tue Nov 01, 2011 6:57 pm
il prolly rebuild it somtime this winter, might even put some bigger jugs and pistons in it
