It is currently Sun May 03, 2026 2:36 am
PostPosted: Wed Oct 02, 2013 6:17 pm
rail buggy, vw based, A arm suspension 16" travel
Item Id: 231066520299
Starting price: $3,000.00
End time: Oct-09-13 08:35:15 PDT
rail buggy, long A arm front suspension 16" of wheel travel, FOA dual spring/rate coilovers front/rear, rack and pinion steering, steering quickener reversed, 4 wheel wilwood disc brakes, CNC steering brakes with front/rear locks/cut offs, hydraulic clutch, metal body, padded buckets with 4 point harnesses, 091 6 rib/4spd tranny with superdiff, 930 conversion with HD high angle joints, 3x3 axles, tubed trailing arms, 1915 motor with single weber carb 40, oil tank with cooler/fan, 30" front tires, 33" TSL super swampers with 32 beadlocks/tubes, ridiculous ground clearance, everything is new,
the bad; front nose of frame tweaked but is still useable, have used it awhile this way, engine has a miss from a plug wire that got burnt/fouled plug, engine still starts runs fine, may get that fixed before auction ends
over 12k in build
located in knoxville, tn pick up only !
PostPosted: Wed Oct 02, 2013 6:19 pm
Lol, I just seen that on eBay myself 5 minutes ago. Chad :mrgreen:
PostPosted: Thu Oct 03, 2013 11:53 am
i saw that on C-list. 3k was his asking price!
PostPosted: Fri Oct 04, 2013 10:47 am
i had it on clist for 6k, then a make offer ad
its on ebay started bidding at 3k......no reserve
PostPosted: Fri Oct 04, 2013 11:43 am
sorry bout the misinformation. wasn't trying to put your buggy on half-price sale! :lol: i've looked at too many ads.
