It is currently Mon Apr 29, 2024 12:29 am
PostPosted: Fri Mar 29, 2013 1:14 am
MadMike this is what I was telling you about. Work's perfect for the delrin bushings. I don't know all the details so I'll let Dave give them.
PostPosted: Fri Mar 29, 2013 8:12 am
Not to steal a thread, but do these work very well? I use the white delrin bushings.
http://www.harborfreight.com/11-piece-a ... 38577.html
PostPosted: Fri Mar 29, 2013 9:11 am
we use the harbor freight reamer (supplied courtesy of odyknuck) it works just fine and it is adjustable.
i might have to "barrow" :wink: the afterburnt reamer to compare the two.
- Sigmund Freud
- Antonio Meloni
PostPosted: Fri Mar 29, 2013 2:39 pm
Actually my Reamers are from ENCO. Got them for 20 bucks when they closed down the Engle road branch. I will say that hard plastic like Delrin is about the only material they work well on lol. As I recall they suck on the softer Urathane bushings as they scalaop the bore. I would think afterburnts hole saw setup would work better for Urathane.
PostPosted: Fri Mar 29, 2013 3:31 pm
this set up I made. works very very good. its so easy. and fast. Basically its an inch and half hole saw, with a insert that I made. the insert is made out of mica, it could be made out of anything, i just happened to have some mica laying around the shop. I turned down the od to fit in the uncut bushing as a guide. and i cut some clearance back for the chips. In the center I drilled a quarter inch hole at the end and pounded a quarter inch dowel pin in it. and I just inserted it to where the drill bit goes in the hole saw. after your done drilling out the bushing. the hole saw will give you just enough clearance so that the trailing arm with a inch and a half shaft will move freely with no slop. :mrgreen: I have the reamers and they are a pain in the butt. they absolutely do not work on urethane like steve says. I found that even with the delrin bushings, if you dont have a tight fit in the beam the bushing will grab and spin around with the reamer. I have used this set up on a couple of front ends for some friends. all they say is wow, thats nice. :mrgreen:
PostPosted: Sat Mar 30, 2013 5:45 am
whats the dimensions on the mica?
PostPosted: Sat Mar 30, 2013 10:59 am
brad has it over his house maybe he can mesure it .its just a slip fit in the uncut bushing. the small end is about 1" od to allow room for the chips
PostPosted: Sat Mar 30, 2013 6:10 pm
That's what I had envisioned when you explained it to me. Neat stuff.
Necessity is the mother of invention.
PostPosted: Sun Mar 31, 2013 12:14 am
thanks 8)
PostPosted: Sun Apr 21, 2013 1:13 am
Users browsing this forum: No registered users and 36 guests
