Thanks for the reply's
wrongwayray wrote:
Dont do it. Mine wrre cut down. The spring plates beat the lip open and a few c.v.s later I figueed out what was foin on. Have to use limit sraps now. Not even enough good metal to weld on spring plate tab kit. Bottom is opened all the way up. Few good jumps and bam.
Wrong way, let me make sure I understand what you're describing. You cut off the spring plate bump stops, you did not use limit straps, and the spring plates slammed into the torsion bar cover plate and eventually destroyed it and part of the torsion housing? You also broke some cv's. Then later you installed limit straps and stopped breaking cv's. But now the housing or spring plate cover can't be fixed?
