It is currently Sat May 02, 2026 1:43 pm
 Post subject: motor and trans ?
PostPosted: Tue Dec 20, 2011 10:35 pm
I was woundering what is the easiest and the best way to move the motor and trans back? The only thing i've come up with is bolt in a bellhousing to the original location and then make knew mounts on the motor side of the trany. If any body has a better and easier idea i would appreciate the help. thanks
 Post subject: Re: motor and trans ?
PostPosted: Tue Dec 20, 2011 10:51 pm
If you can get in touch with willie he did that. he slid the motor and trans back like 2 inches on that orange single seater he had.
PostPosted: Tue Dec 20, 2011 10:55 pm
thanks for the info
PostPosted: Wed Dec 21, 2011 1:07 am
I've done that, moved mine back 1.5 inches.
1. Cut through frame engine support horns near their ends and added tubing spacers to extend horns.
2 Extend front tranny mount by cutting it off and adding spacer between it and the torsion, with extra bracing.
I did all this with tranny in place to make sure everything was all lined up, tack welded the new mounts, so I could still move things around.
3. Removed tranny, then welded all the extended mounts up.
4. Mine is mounted top and bottom of the bellhousing.
I supported tranny with ratchet straps from the frame, while I was extending all the mounts.
