It is currently Wed May 01, 2024 11:22 pm
 Post subject: Timing w/racing fuel
PostPosted: Sat May 11, 2013 10:22 pm
What is the best degree mark for 10:1 c/r ratio with 111 octane? 82x92 stock heads 5.5 vw rods.oo9 dist with electronic module.Dual weber 45's.
 Post subject: Re: Timing w/racing fuel
PostPosted: Sun May 12, 2013 4:19 am
every engine may want something different, that being said, most end up somewhere between 28* & 32* but unless ive checked the pulley to make sure the timing marks are right I usually start with 30* at 3000 rpm and see how it runs
also you might want to check that 009 and see how much its advancing especially if its not german made
PostPosted: Sun May 12, 2013 11:06 am
I've just got a stock pulley on it, so I don't know where 30 degrees is. I forgot to mention that. I was more interested in the idle timing.
PostPosted: Sun May 12, 2013 11:55 pm
I usually don't worry about idle timing unless im just checking the advance of the distributor, and the only 2 suggestions I would have for a stock pulley is get a new pulley, or a timing light that you can dial in the advance and then you can set the pulley to 0*, but a degree pulley should be cheaper than a good timing light
Users browsing this forum: No registered users and 16 guests
