It is currently Mon May 04, 2026 7:02 am
 Post subject: What Carb is this?
PostPosted: Sat Sep 25, 2010 6:23 pm
Appears to have "32 36DEAV" On the bottom. Previous owner let it sit and gum up, now I can't get it to idle smooth. If I can get a rebuild kit for cheap that it would be worth it to rebuild it.
Bought Buggy- Sept. 12.
Currently fixing the things that weren't finished by previous owner, and getting the Title straightened out so it can truly be Street Legal.
 Post subject: Re: What Carb is this?
PostPosted: Sat Sep 25, 2010 6:42 pm
looks like a progrssive weber to me but not 100% sure, it depends on the engine size and combination whether or not it will perform well
PostPosted: Sat Sep 25, 2010 6:46 pm
Thats what it looks like to me too.Years ago i ran a pinto carb that looks just like a weber progressive and it performed great for the little motor i had it on.
PostPosted: Sat Sep 25, 2010 7:21 pm
Often they can be time consuming to jet as it seem like they are all sold with jetting for a stock or mild cammed 2.0 T-4 engine. Preheat and lots of it makes it work well, without it the intake ices up in cold weather causing the engine to quit and has to be jetted pig rich in cool and warm weather. You might have to wrap the preheat tubes and intake with header wrap to keep enough heat in when it is cool/cold outside. Each change requires being a magician or removing the carb from the manifold. When they were on Pinto engines they were easy to work on.
Here is an article that does a good job explaining how the progressive works.
Is the Weber Progressive Right for Me?
By Ray Heath, with portions from other sources as noted.
For 1600 to 1835 DP engines - everything from the best sources in one place.
For more tuning information, see http://www.1800vw.bizhosting.com/progcarbtune.htm.
When you order a Weber Progressive for your air-cooled motor you are never quite sure what the jetting will be. Over the years various changes have been made to the main and air correction jets without any real plan from a sellers point of view. The Progressive in its various models have been used on over 100 models of cars and trucks, foreign and domestic, in factory and aftermarket applications. Also the type of Progressive you may receive might be different from the one you ordered or expected to get.
The linkage setups for air-cooled VW work on both the DFAV/DGAV and the DFEV/DGEV carbs. The "E" is for electric choke and the "A" is for water choke. Make sure you get an electric choke as hot water is hard to come by in an air-cooled vehicle. The DGEV is the mirror of the DFEV and have been used successfully in dual carb setups for 2500 cc and above type IV and Porsche engines although the response is not as snappy as other types of dual carbs. If you have an application for dual 48's then dual Progressives might be a little more streetable. The DGEV come with a solenoid fuel shut off valve just like your original Solex, but you will need to lengthen the solenoid wire to reach the front mounted cutoff on the Progressive.
The first carb I took apart had the following jet setup:
Primary Secondary
Main #132 #145
Air Correction #165 #160
Idle #60 #150
This is what I used as my base line for setting up this 32/36 DFEV carb. My 28/36 DCD out of a 72 Ford Pinto has a completely different jetting. Because they are hard to come by nowadays, even though I consider their range much better and they are manual choke, I am leaving this article to carbs that are available. You might have different jets installed in your 32/36 and will have to make a determination as to what works best for your motor. If you get lucky you will have received a carb that has been jetted properly. This has happened to me a couple of times when I bought a rebuilt carb kit. One of the places I have ordered rebuilt carbs from is Larry's Off Road. The carbs they sell have been previously used in VW applications and will most likely have correct jetting.
The major problems when installing the Progressive carb are due to dirt and air leaks and debris in the intake runners. In the past it was possible to find that the intake manifold runners were too long. Today you may still find that situation when the crankcase cylinder faces have been surfaced or the heads fly-cut to raise the compression. This will narrow the engine causing an excessive runner length. Make sure that when the intake castings are bolted down that the center section is still loose in the boots. It is an excellent policy to always check the runners for dirt and debris. Some of the center sections come with the heat risers molded in place and others you have to assemble. Still other makes of intake center sections have no provision for heat risers at all. Make sure that your application is correct for the type of intake you get. The majority of uses are for street vehicles and will require the heat riser. This is a heavy carb and manifold so you need to install a bracket to take some of the strain.
If you suspect dirt in the carb, even if it is brand new, there is a little trick you can try prior to tearing it down. This is how it happens. Dirt will build up over a time in your fuel lines and even new lines will have some residue. When the lines are wiggled while changing carbs or fuel filters, some of this will break loose and flow into the carb. A trick to break loose this dirt is to rev up your engine and then slap your hand over the top of the carb creating a huge vacuum. This will usually suck the dirt right through. The hard stuff that is still lodged in the fuel circuit will necessitate tearing down the carb regardless.
During the adjustment and re-jetting process you will want to have a spark plug color chart to check where your burn is and decide which direction to go. You can usually pick these up at the auto parts store or there may be one in your repair manual. These are good to see where you are at in the process. I found a good color chart in an old Clymer's shop manual for a different vehicle. It will work fine for this.
As a baseline you will want your motor to be in peak adjustment. That means the distributor timing is set, the points and plugs are gapped properly, and the valves are adjusted. If you are running larger aftermarket heads and have some intake porting, it is suggested to get the larger diameter intake manifold end castings available through many of the VW parts suppliers listed in the VW mags.
Carb adjustment starts out with your float setting in your float bowl. I am like you, I'd rather not take the carb apart first, just use it out of the box with some minor exterior adjustments. The float setting is critical to everything else and must be checked. Floats can be out of whack from poor manufacture or remanufacture to just being jostled during shipping. You need to know where it is before changing anything else. Do the next step before installing on the engine.
The top and bottom surface of the float must be parallel to the gasket surface of the float bowl. To check the bottom surface of the float you need to hold the carb upside down at about 45 degrees (this keeps the weight of the float from compressing the small spring in the float needle). The gasket surface to the bottom surface of the float should be about 1.5" or 38.5mm.
I like to set up this carb on an engine start up stand in order to get to all the hard to reach places, most of you do not have this luxury. Before changing jets you need to check out the low speed settings as they will affect your motor from idle to over 3000 RPM. Back out the idle screw (it's the one on the linkage on the left side of the carb). Then screw it in until it just starts to move the primary butterfly (be sure the choke is full open and place your finger on the butterfly to tell when it first starts moving). Then turn it ONE FULL TURN.
Next item is to set the idle richness screw -- that's the one below the choke on the front of the carb that's impossible to get to. This screw controls the amount of pre-mixed air and fuel. Screw it all the way and lightly bottom it out. Then back it out two (2) turns. I use a real short fat handled screw driver to get to this beast.
The factory VW fuel pump will handle the supply to this carb under all but the most strenuous running. On dune buggies and vehicles that really wind up you will need to install an electric fuel pump and a fuel pressure regulator. I set the regulator to halfway for the base install. Now start the motor and let it warm up without changing the screw setting. Once the motor is warmed up and the choke has fully rotated, screw the idle richness screw in or out until you hit the highest RPM.
Next, after letting your motor cool you must check how many turns out the idle richness screw is. Be very careful not to bottom out the screw hard when you do this. If the idle jet is the correct size you will be 1 3/4 to 2 1/4 turns. If you are less than 1 3/4 turns out, install a smaller idle jet and if it's more than 2 1/4 turns out you need to install a larger idle jet. The only idle jet we will change in this article is in the primary circuit as the secondary jet (140-145) is large enough to handle the demand when the secondary is engaged.
If you had to change the idle jet (the one on the left of the choke element) then go back and adjust the idle mixture screw again until you end up with it out about two turns for the highest RPM. You may want to turn it out another 1/2 turn to richen up the idle to compensate for low end drop out when the accelerator is pressed.
Now that the low speed circuit is properly adjusted you can now use your spark plug color chart for adjusting the main and air correction jets.
The backyard method, but one that works well, is to slowly run your engine up to 3500 RPM while attached to your tach and view the main jet in the venturi. It should start dripping fuel at this RPM into the throat of the venturi. If the fuel starts dripping at a much higher RPM then increase your main jet. If fuel starts dripping at a lower RPM than 3500 then decrease the size of your main jet. An engine installed in a Beetle or bus will force you to use a light and mirror to see this. Not everyone has an engine start up stand. I use an explosion proof sealed fluorescent shop light in the engine compartment.
Although some low end throttle response can be helped through more initial spark advance, be careful where you set your timing. Too much advance too soon can be sure death to your motor. You don't want your advance all in before you hit your cruising RPM.
You will notice that the air correction jets were never mentioned. The carb comes with all the air correction needed for any engine jetting from 1600 cc to 1904 cc. Your mixture setting and main jet size is what is important on this carb.
For my specific use on an 1835 cc engine with 041 39 X 35 valves, a 009 distributor, and a stage 2 cam I came up with the following setting:
Primary Secondary
Main #137.5 #145
Idle #65 #150
It's a hassle to set up and time consuming. That's why a lot of people give up and say that the Progressive is useless for VW application. Like all carbs, they have to be set up to match your engine size, but when dialed in, will perform satisfactory and give good mileage at the same time. You have the extra benefit of being able to stomp on it when you want to play and have extra umph available for that race to the stop light or passing on the highway.
Weber with a vacuum advance distributor
PostPosted: Sat Sep 25, 2010 8:17 pm
http://www.webercarbsdirect.com/32_36_D ... 0.051b.htm ???
PostPosted: Sat Sep 25, 2010 8:32 pm
the letters indicate what kind of choke it has in some cases.
PostPosted: Sat Sep 25, 2010 8:52 pm
According the the long post a few above, My carb is designed for a Water Cooled Engine? Or at least it requires hot water to work correctly.
Perhaps that's why I can't get it to idle well.
Wonder if I could just buy this http://www.webercarbsdirect.com/product_p/57804.332.htm and make it electric?
PostPosted: Sat Sep 25, 2010 11:27 pm
You can get it to idle without preheat. It is off idle and cool temps in pre 60 degree outside temps that the intake will ice up. Preheat on a VW engine like most engines is from the exhaust crossover. If your intake is not set up for it you could wrap the intake in two 3/8 brake line tubes up and down the intake, wrap it in header tape and attach one end to to the exhaust exhaust port and the other to the collector portion of the exhaust like the factory did.
