Ecotec 2.4 mid travel http://www.woodsbuggy.com/phpBB3/viewtopic.php?f=23&t=9243 |
Page 6 of 8 |
Author: | Psycho Alpha [ Sun Jun 01, 2014 12:04 pm ] |
Post subject: | Ecotec 2.4 mid travel |
This being my first build, there are some things I would of done different in hindsight but I am very pleased with the finished product. The attention to detail in yours is awesome! If we ever end up at same place maybe we will have to find out how they run...... "Don't believe everything you read on the Internet."--Abraham Lincoln |
Author: | Psycho Alpha [ Sun Jun 01, 2014 12:08 pm ] |
Post subject: | Re: Ecotec 2.4 mid travel |
Twotrackerbryan wrote: Psycho Alpha wrote: Twotrackerbryan wrote: I knew it was going to be a heavy car. 2300 total with all fluids filled to the top. 320 left front 320 right front 840 left rear 820 right rear What I find interesting! Is that as different as your buggy is to mine, they have almost identical weight distribution and HP to weigh ratio "Don't believe everything you read on the Internet."--Abraham Lincoln We just cant let Helmetguy chime in with hp to weight ratio! Lmao "Don't believe everything you read on the Internet."--Abraham Lincoln |
Author: | Twotrackerbryan [ Sat Jun 07, 2014 12:39 am ] |
Its quick, and by the way...Helmet guy is 243hp with 228 torque at 1540 lbs (badass) https://www.youtube.com/watch?v=yWjUbMv ... e=youtu.be |
Author: | PhillipM [ Sat Jun 07, 2014 8:18 am ] |
Is it just the camera or is there a shitload of anti-ackerman on that front end? edit - must be the camera, or just the tracking? |
Author: | Twotrackerbryan [ Sat Jun 07, 2014 11:44 am ] |
It is the camera. Gopro's have the fisheye effect and even when you check the box for removing the fish eye effect in the Gopro studio, you still get it to some effect. I went with a center load rack to get rid of the bump steer as well as the anti ackerman. To get the tie rods to clear the frame and keep the problems out was a pain. If you look early on in the build you can see how I solved it by cutting the frame and adding a bend. |
Author: | PhillipM [ Sun Jun 08, 2014 7:10 pm ] |
I had a similar issue with ours, although I raised the outer steering pivots, dropped the frame tube a little then gussetted it to retain it's strength, still tight clearance-wise though. |
Author: | BAJABUGNUT [ Sat Sep 06, 2014 2:24 pm ] |
Ouch..... You think u pay that much for shocks they would handle that, but to them it's ur fault cuz u didn't set them up right... |
Author: | NRIbuggys [ Sat Sep 06, 2014 3:46 pm ] |
No limit straps? Sent from my iPhone using Tapatalk |
Author: | Twotrackerbryan [ Thu Sep 11, 2014 11:26 am ] |
NRIbuggys wrote: No limit straps? Sent from my iPhone using Tapatalk Interesting question! I did have them, they were in the storage compartment of the motorhome. Under the original configuration I lost about two inches of wheel travel and when I went back to the guy that helps me with the suspension work he said I was fine to run without them. And yes they are going back on. |
Author: | Alpha Fab [ Thu Sep 11, 2014 1:51 pm ] |
Look good man! Let's go riding! |
Author: | PhillipM [ Fri Sep 19, 2014 10:38 pm ] |
Never had any trouble without limit straps, but it does depend on mounting angle and how much preload you're running. |
Author: | Twotrackerbryan [ Sat Sep 20, 2014 8:44 pm ] |
PhillipM wrote: Never had any trouble without limit straps, but it does depend on mounting angle and how much preload you're running. I finally got a chance to get back to Dans to see what had happened. The best we can figure is before I got the rear shocks dialed in I had way too much rebound and basically stretched the retaining clip section to point of failure. When I say too much rebound, I was bouncing on the rough sections. The preload was perfect and was less than an inch. The problem was I should have not run the buggy hard until I had the valving done correctly. I know most of you think I am crazy but the shocks are going back on and with no limit straps. I will chalk this one as an expensive learning curve. |
Author: | PhillipM [ Mon Sep 22, 2014 10:09 am ] |
What are you running rebound stack and spring-rate wise? The twin rears on ours are both on 185lb springs, and the rebound stack is roughly around a 90/100 stack if it was a standard Fox stack (it's not, but similar figures - stiffer low speed and softer high than the standard stack). Only using one pair of dampers for limiting the droop however. |
Author: | Twotrackerbryan [ Sun Dec 28, 2014 12:14 pm ] |
PhillipM wrote: What are you running rebound stack and spring-rate wise? The twin rears on ours are both on 185lb springs, and the rebound stack is roughly around a 90/100 stack if it was a standard Fox stack (it's not, but similar figures - stiffer low speed and softer high than the standard stack). Only using one pair of dampers for limiting the droop however. Not sure what I have. I run it for a bit and then take the shocks back in and tell my suspension guy what it is doing and he makes the adjustments for me. |
Author: | Pettigo [ Sun Dec 28, 2014 12:53 pm ] |
That's cool |
Author: | helmetguy [ Sun Dec 28, 2014 3:12 pm ] |
Thats a really nice buggy!!! All of your hard work shows in that picture!! |
Author: | FOX SHOX [ Sun Dec 28, 2014 3:34 pm ] |
Where did you get the top made at? I would like to get a top for the tub buggy. Thanks Dave T |
Author: | Twotrackerbryan [ Sun Dec 28, 2014 5:15 pm ] |
FOX SHOX wrote: Where did you get the top made at? I would like to get a top for the tub buggy. Thanks Dave T Johns Custom Upholstering in Battle Creek Michigan. He is expensive but I guarantee you will not find a better finished product. |
Author: | Twotrackerbryan [ Sun Dec 28, 2014 5:18 pm ] |
helmetguy wrote: Thats a really nice buggy!!! All of your hard work shows in that picture!! Thank you! Spring couldn't come fast enough this year. It sucks seeing it just sit in the garage. |
Author: | FOX SHOX [ Mon Dec 29, 2014 5:14 pm ] |
Shoot street legal? and the new top, ride ride ride!!! I have a broken trans or else I might. |
Author: | jeep534 [ Tue Dec 30, 2014 10:28 am ] |
First off wonderful build. I am chrious about your front beam/suspension Thank You archie |
Author: | Twotrackerbryan [ Wed Dec 31, 2014 1:15 pm ] |
jeep534 wrote: First off wonderful build. I am chrious about your front beam/suspension Thank You archie Thank you, what exactly would you like to know about the front end? |
Author: | jeep534 [ Wed Dec 31, 2014 6:17 pm ] |
Twotrackerbryan wrote: jeep534 wrote: First off wonderful build. I am chrious about your front beam/suspension Thank You archie Thank you, what exactly would you like to know about the front end? Did you make the front beam and how did you do it ( materials ) and how are the arms held in place. I have metalworking machines Thank You archie |
Page 6 of 8 | All times are UTC - 5 hours [ DST ] |
