New Stalker frame with turbo suby power http://www.woodsbuggy.com/phpBB3/viewtopic.php?f=23&t=9147 |
Page 7 of 7 |
Author: | BigScott [ Mon Sep 23, 2013 10:35 pm ] |
Post subject: | Re: New Stalker frame with turbo suby power |
MadMike wrote: BigScott wrote: giveitagallon wrote: Great work ! Guess ya figures the machine out already ? Thanks! I'm learning, lucky for me I have a friend who programs and runs cnc machines for a living and he has helped me a lot! <img src="http://www.woodsbuggy.com/plugins/system/yvsmiley/phpbb/icon_e_biggrin.gif" alt="Very Happy" class="yvSmiley"> Damn, I was looking forward to "camping out" in your barn. I'm still looking forward to that! My buddy is a great machinist and can design stuff on the computer to use the cnc mill, but he is not a fabricator. I'll be ready to learn some stuff whenever you can make the trip!! |
Author: | MadMike [ Mon Oct 14, 2013 11:25 pm ] |
Looks great Scott, and nice weave on the TIG Dan. One thing should be noted, Big Scott is running a half shaft axles instead of plunging axle CV's. If he were running CV's the internal weld would need to be machined some to allow the axles to plunge into the flanges. |
Author: | giveitagallon [ Fri Oct 18, 2013 7:58 am ] |
Very nice work guys ! Your on the homer roll for this build ! |
Author: | BigScott [ Sat Oct 19, 2013 7:38 pm ] |
MadMike wrote: Looks great Scott, and nice weave on the TIG Dan. One thing should be noted, Big Scott is running a half shaft axles instead of plunging axle CV's. If he were running CV's the internal weld would need to be machined some to allow the axles to plunge into the flanges. Thanks mike, I drove it and they work great! giveitagallon wrote: Very nice work guys ! Your on the homer roll for this build ! Thanks, a lot of buddy's have helped me out over the course of this build and it's much appreciated! |
Author: | BigScott [ Sun Oct 20, 2013 8:19 pm ] |
Got the headlight mounts made, we drew them up and had HalfCab laser cut them. |
Author: | MadMike [ Tue Dec 10, 2013 12:24 am ] |
I'm thinking that in a roll over, that would just fold over without some kind of triangulation. Doesn't look like there's enough room anywhere to do that. |
Author: | BigScott [ Tue Dec 10, 2013 12:41 am ] |
MadMike wrote: I'm thinking that in a roll over, that would just fold over without some kind of triangulation. Doesn't look like there's enough room anywhere to do that. I was thinking the same thing |
Author: | Sandbar Norm [ Tue Dec 10, 2013 7:45 am ] |
I like the look of the added roof bars. I'm sure you already though of this but how about on the rear of the top bar going down to the rear towards the inside or outside of the shock? It still may not be enough and need some in the front also. Also, great looking build. Norm |
Author: | jason108 [ Tue Dec 10, 2013 8:23 am ] |
Or to the tree bars keep us updated looks great Posted using the WoodsBuggy Mobile App |
Author: | nitro_mudder [ Sat Mar 01, 2014 1:41 am ] |
MadMike, that is a LOONNGG Drive. Honk as you go by. |
Author: | BigScott [ Sat Apr 19, 2014 8:56 am ] |
It was like Christmas in April, ups and fedex dropped off some goodies! The new 30" LED light bar, in case the lights go out in the shop I can still work on my buggy. Seeing how it's spent 3yrs in the shop and only 1 day on the trails!! The new parallel trailing arms from Precision Alloy, thanks to Todd and Dave for a badass set of arms! Big difference compared to my old arms |
Author: | vw1915hillstomper [ Tue Apr 22, 2014 2:01 pm ] |
Awesome looking build!! Lovin the stalker frame setup and that Suby turbo engine should scream Good luck with the rest of the build and I cannot wait to see it completely finished!! |
Author: | TATTOO [ Fri May 09, 2014 6:47 pm ] |
NICE WORK... |
Author: | BigScott [ Fri Jul 10, 2015 8:50 pm ] |
After 2 sets of arms and then cutting the second set up to make them work, they are on! Sent from my iPhone using Tapatalk |
Author: | RaceBugg1098 [ Mon Jul 13, 2015 8:23 am ] |
looks good! what was the problem with the other arms? |
Author: | BigScott [ Mon Jul 13, 2015 10:25 pm ] |
RaceBugg1098 wrote: looks good! what was the problems with the other arms? I ordered the arm to be setup up to have a parallel swing instead off the standard Vw swing. They did a great job on the arms but once I mounted one I realized that it was about 2.5 " to long, come to find out when they setup the jig they measured from the center of the torsion instead of the center of the mount that was going to be welded to the rear of the torsion. So I sent them back and they built another set for me and they were perfect. Then once I got one of the new ones mounted and cycled the suspension the drive shaft hit the arm with about 2.5" of travel left. So I cut the arms apart and changed the angle of the upper bar and all is good. Lol |
Author: | RaceBugg1098 [ Tue Jul 14, 2015 8:29 am ] |
Great work, it looks mean!! |
Author: | darrell [ Tue Jul 14, 2015 2:58 pm ] |
Nice looking buggy |
Author: | GoMopar440 [ Sat Jul 18, 2015 1:55 am ] |
On soft metals I always used some soft aluminum or copper scraps as shims between the chuck jaws and the part. 1/8" to 1/4" thick pieces have usually worked well for me. You can use a piece of tape to hold the shims to the jaws so they don't fall out when you dial in the part. |
Page 7 of 7 | All times are UTC - 5 hours [ DST ] |
