It is currently Tue May 05, 2026 2:29 am
 Post subject: all wheel drive buggy ??
PostPosted: Sun Jun 27, 2010 11:57 am
sorry if this is in the wrong forum but didnt know where else would be better... im just wondering why no one ( atleast that i can find ) has built a 4 wheel drive buggy maybe using a 4 wheel drive bus tranny? and im not talking about building a mid engine rock crawler either, just a regular buggy with a front drive axle.
auto body & paint discussion... www.benscollision.com/forums
PostPosted: Sun Jun 27, 2010 12:22 pm
With a rear engine you wouldnt have enough weight up front to get much traction out of the front wheels. Hard to justify the extra weight and power loss for little traction gain. Needs to be mid engine to get some front traction gain.
PostPosted: Sun Jun 27, 2010 2:01 pm
im no expert but i would think adding the axles & equal diameter tires up front would easily be 100/ 150 lbs, on such light vehicles that is a significant amount of weight. and the hp loss could be compensated for fairly easy.. im not new to playing off road, but ive only had my buggy for about a year so i am fairly new to it and ive high centered this thing a couple times already, thinking if it was 4wd it might have pulled itself through
PostPosted: Sun Jun 27, 2010 2:19 pm
Picture it like backing a 4wd up a hill, the back tires barely touch. I agree the added weight of the 4wd parts will help some on flat ground, but I doubt they do more then fling dirt at you. The reason for rear engine is that it gets the best traction due to weight transfer to the only drive wheels. Mid engine would also keep the nose down on steep hills better. Just some thoughts of mine, been trying to design one of these myself. I could very well be wrong, it is just all theory at this point.
PostPosted: Sun Jun 27, 2010 7:25 pm
yeh nothin like kickin around some theroy.. i'd say your right, mid engine would be better weight transfer but im thinking if i used a 4wd vanagon trans it would keep the build simpler, and by keeping most of the weight in the back the buggy could still 'skip' through mud or something soft that a front heavy vehicle would nose dive into...?
PostPosted: Sun Jun 27, 2010 9:54 pm
a used 4 x 4 bus tranny sells for around 1500.00 and then u got to find a front end,they are pretty rare,i have seen a 4 x4 buggy it had a subaru front end under it and did real good,and it had small tires on front to
PostPosted: Mon Jun 28, 2010 8:59 am
have any pics of it?
PostPosted: Mon Jun 28, 2010 11:06 am
Not worth the expence and effort to have less than a rear engined rear wheel drive Buggy. Only would need 4 wheel drive on rare ocassion. For those a winch is handy lol.
PostPosted: Mon Jun 28, 2010 11:10 am
no its been a couple yrs ago
cron
