What did you do to you buggy today? http://www.woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=15751 |
Page 21 of 21 |
Author: | bigDsmith [ Thu Apr 02, 2015 9:18 pm ] | |||
Post subject: | Re: What did you do to you buggy today? | |||
Yahoo..I finally finished my air bag setup. Sent from my VS985 4G using Tapatalk
Author: | aboone993 [ Thu Apr 02, 2015 9:22 pm ] |
Good deal ! I am waiting on my torsion eliminators from Mike ...I hope the USPS hasnt lost them ! Where did you get your bump stop rubber ? |
Author: | bigDsmith [ Thu Apr 02, 2015 9:57 pm ] |
Can't remembet, but summit racing had them for $12.97. Sent from my VS985 4G using Tapatalk |
Author: | Cush53 [ Thu Apr 02, 2015 11:03 pm ] |
I have the same ones got them at summit, I'm spoiled summit is 20 min from me |
Author: | aboone993 [ Fri Apr 03, 2015 9:10 am ] |
Thanks I will order some .I wished we had one close here . It would be like a Mans toy store ! |
Author: | jeff69 [ Sun Apr 05, 2015 10:53 pm ] |
Well we have been grinding the case and trying to get the bottom end of motor together. And finishing up on the shifter too I'm so ready to finish and do some riding Sent from my iPhone using Tapatalk |
Author: | mydadsagearhead [ Sat May 16, 2015 6:54 pm ] |
I put mine on the dyno.....79 ponys 91 foot pounds of torque and 1650 total gross weight. Bam!! Built'er from the ground up. I did that. Your welcome. |
Author: | Psycho Alpha [ Sun May 17, 2015 12:32 am ] |
mydadsagearhead wrote: I put mine on the dyno.....79 ponys 91 foot pounds of torque and 1650 total gross weight. Bam!! Built'er from the ground up. I did that. Your welcome. what engine?
Author: | mydadsagearhead [ Sun May 17, 2015 10:58 am ] |
1835cc vw duel 44 webers. It's on You Tube. Crows Dyno pull 1835cc |
Author: | Psycho Alpha [ Sun May 17, 2015 4:05 pm ] |
http://youtu.be/RFWzz0aT01E |
Author: | bigDsmith [ Sat Jun 20, 2015 11:12 pm ] |
Got my steering wheel, shaft and r/p fixed from the wildcat trip. Now working on new shocks for the front. |
Author: | MickeyMouse [ Sun Jun 21, 2015 3:09 am ] |
Darrin, Finley and I had a blast riding with you Saturday night. Look forward to riding again at the next event or we will need to meet up at WindRock or Tellico. |
Author: | bigDsmith [ Sun Jun 21, 2015 9:24 am ] |
Dan, I'm not going to Chocco but shooting for Rush. See ya then or maybe sooner. |
Author: | MickeyMouse [ Sun Jun 21, 2015 11:53 am ] |
Sounds good... I will be a Choccolocco but I am not sure I am going to make Rush. I am trying to talk my wife into letting me get a new Tow Rig. So far, things are not going in my favor.. |
Author: | bigDsmith [ Sat Jun 27, 2015 7:23 pm ] |
Installed new fronts shocks and bump stops. |
Author: | Kaz [ Wed Jul 01, 2015 10:46 pm ] |
needed a rear bumper for mine. it never had one. bought a baja rear bumper but the top arms that would normally go to the rear shock towers werent long enough. i needed mine to go to the frame. and i wanted it removable in case i need to drop the motor or trans.so i cut some 1 1/2 tubing to ad length to the top arms and built a sleeve to weld into on the bumper side that the whole bumper assembly slides onto the mounting points on the cage and tranny mount. bolts on. soon as i get everything welded up itll be really nice.going to ad a rear skid plate to it once its fitted and welded.kaz |
Author: | ChaindriveJeff [ Fri Jul 10, 2015 11:07 pm ] |
"Assessed the damage" of a freakin barrel roll at Wildcat last weekend!!! First was easy, the next 2 was hard hits to the roof and rear cage, then landing flat on all 4's. Luckily just cage damage, nothing else! Gf and myself was belted in tight, with only a couple bruises to each of us! |
Author: | chaindrive [ Fri Jul 10, 2015 11:10 pm ] |
Sent from my SAMSUNG-SGH-I337 using Tapatalk |
Author: | Pettigo [ Sun Jul 19, 2015 10:42 am ] |
. Anyone know these boys?? Sent from my iPhone using Tapatalk |
Author: | bigDsmith [ Sat Dec 19, 2015 10:15 pm ] |
Switched my pivot bolt washers both to the inside. Sent from my VS985 4G using Tapatalk |
Author: | stevie [ Wed Dec 23, 2015 6:14 pm ] |
bigDsmith wrote: Switched my pivot bolt washers both to the inside. Sent from my VS985 4G using Tapatalk I have one on the outside and one on the inside, what was the reason for putting them both inside? |
Author: | bigDsmith [ Wed Dec 23, 2015 8:09 pm ] |
I've read they are used to move the arm in and out. This helps in the centering of transaxle in relationship to your axles. Sent from my VS985 4G using Tapatalk |
Author: | Cush53 [ Thu Dec 24, 2015 12:12 am ] |
I have also had to move them to get more toe in adjustment Sent from my XT1080 using Tapatalk |
Author: | bigDsmith [ Fri Apr 15, 2016 9:53 pm ] |
Moved my light bar down from bottom of windshield to front. Didn't like the way it lighted up the front of my buggy. Sent from my VS985 4G using Tapatalk |
Page 21 of 21 | All times are UTC - 5 hours [ DST ] |
