It is currently Sat May 04, 2024 2:36 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Suby thermostat
PostPosted: Fri Jan 14, 2011 5:04 am
Firebug wrote:
My heater hose is a loop to allow circulation...I also bypassed the throttle body, , this hose also is a loop to allow a cooler throttle body. My first suby engine,,,an ea81 has the thermostat in the top hose (same radiator). I think the thermostat in the bottom is fine for grocery getters. It is the continuous high revs that overcome the cooling system with the thermostat on the bottom.
I see. I misunderstood the discussion, and thought you had it blocked off.
The EAs didn't need revs to overheat :lol:
Plenty of EJs see high revs without overheating. I tracked my EJ22 wagon many times with an EA82 radiator. Even our built STi rally car did just fine with the stock system. We are running an aftermarket radiator now, but only because the stupid plastic endtanks cracked :roll:
Whatever the reason. It's a cool idea, and if it's working, than good work!
Subaru wiring: NumbchuxConversions
PostPosted: Wed Jan 26, 2011 3:12 pm
So far with some hi revs and bumps, the temp stays at 180-190 with a 170 thermostat.
PostPosted: Mon Jan 31, 2011 6:33 pm
I noticed my accusump was slow on cold nights so I made a warmer with my heater loop.
PostPosted: Thu Feb 03, 2011 1:57 pm
Haha that's a pretty sweet set up- little solenoid valve and all!
Bite off more than you can chew, then chew like hell.
Users browsing this forum: No registered users and 47 guests
