It is currently Sun May 03, 2026 2:59 am
PostPosted: Wed Apr 24, 2013 9:46 pm
i have power bled them, new brakes, different cutters. and still no pressure. so its master cylinder time.
so what is the most cost effective way to go. i have the dual set, one for the clutch and on for brake.
i am going to leave the clutch alone and just get a brake one.
so VW if so what year or is there something else you all use that works better. it now has sentra calipers on it,
any help is greatly appreciated!
PostPosted: Wed Apr 24, 2013 10:04 pm
Buy a Wilwood 3/4 "
PostPosted: Wed Apr 24, 2013 10:06 pm
http://item.mobileweb.ebay.com/viewitem ... 4055778788
PostPosted: Wed Apr 24, 2013 10:34 pm
davehix wrote:
http://item.mobileweb.ebay.com/viewitem?itemId=190827258077&index=7&nav=SEARCH&nid=04055778788
thanks Dave,
if i can't find something local , i will order this.
PostPosted: Thu Apr 25, 2013 9:37 am
I have a used 3/4" Jamar I will let go for 40 bucks shipped. I went to a 7/8" bore
PostPosted: Thu Apr 25, 2013 9:51 am
i appreciate the offer,
but i think i am going to add on another $13 and get a wild wood brand new.
PostPosted: Thu Apr 25, 2013 4:53 pm
Wliwood
PostPosted: Thu Apr 25, 2013 7:33 pm
Ok 30 bucks shipped. I just want to see it get used without just giving it away. :wink:
PostPosted: Thu Apr 25, 2013 8:33 pm
BTW.. what is the problem you are trying to solve? Are you brakes not working?
PostPosted: Fri Apr 26, 2013 8:18 am
sorry , bought the wild wood yesterday. it will be here monday, hope to have everything ready to go by Friday so i can get to Rush this coming week end.
PostPosted: Fri Apr 26, 2013 8:35 am
when i bought this buggy back before the first of the year, it just didn't seem to have the stopping power.
after my first ride, i know it didn't have the stopping power.
the brakes that are on it i think are those brakes that you buy in a kit that comes with the rotor and every thing. so after seeing how a buddy of mine that is using Sentra Brakes stop on a dime. i went with those.
after getting them installed , they still wouldn't pump up even after power bleeding them.
had a single handle cutting brake on it, change it to a duals that had rebuilt, only time when i could get the brakes to stop was when the peddle was fully compressed and i would hit the cutter brakes then it would stop.
only thing left is the master cylinder. so a wild wood i bought , i will see Monday night if this fixed my issue!! ( I Hope because i don't know what else to do!! ) because from what i have read and people has told me if you can see black in the fluid when you let out on the brake its a good chance that the master cylinder is bad. ( meaning , buy a new one or rebuild it) so i bought a new on and if this fixes it i will rebuild the old one and have as a spare.
PostPosted: Mon May 06, 2013 12:54 am
First of all will this mc bolt up to a set of Cnc pedals. And second
When bleeding after pedal go down pull cut brake hold light pressure
on handle and pump pedal until it pulls handle back down and repeat
Hope this helps. Brakes are a pain in the ass to get working right
Good luck
PostPosted: Mon May 06, 2013 10:11 am
Good luck
basically that is what i did, to get them working and then went out to Rush, and for some reason busted the passenger side caliper, don't know what caused it yet. but its trashed. so back to the drawing board and to the supply house. :( :( :( :(
